OVPN disconnect after few seconds
When connecting from a windows 10 laptop to my OVPN server on the mikrotik it said it’s succesfull on my laptop but still i cannot ping anything or get access to the internet.
I get the ip as configured but that’s it.
Ovpn logs on the mikrotik :
OVPN config :
interface ovpn-server server set certificate=Server-Cert cipher=aes128,aes256 default-profile=openVPN enabled=yes require-client-certificate=yes
Client .ovpn file :
client
dev tun
script-security 3
remote **ip**
resolv-retry infinite
nobind
auth-nocache
auth-user-pass
remote-cert-tls server
reneg-sec 0
cipher AES-256-CBC
proto tcp
explicit-exit-notify 1
<ca>
*********my cert ********
</ca>
<cert>
</cert>
<key>
</key>
bump ! anyone
The subject of your post is it disconnents after a few seconds, but I can see in the log it’s connected for 1 minute at least. So what is your issue? Not being able to ping or getting disconnects?
Are you allowing the traffic coming in from the OVPN trough your firewall?
I’m allowing this in the firewall.
Found out i’m not getting a default gateway…
Do i need to hardcode this in the .ovpn file? or where can i config this?
Add this in your vpn client config if you are using windows :
route-method exe
redirect-gateway
Added, still no gateway
Post your client connection log
Tue Mar 12 22:22:24 2019 Flag 'def1' added to --redirect-gateway (iservice is in use)
Tue Mar 12 22:22:24 2019 OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 26 2018
Tue Mar 12 22:22:24 2019 Windows version 6.2 (Windows 8 or greater) 64bit
Tue Mar 12 22:22:24 2019 library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
Enter Management Password:
Tue Mar 12 22:22:26 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]*****my ip*********
Tue Mar 12 22:22:26 2019 Attempting to establish TCP connection with [AF_INET]*****my ip********* [nonblock]
Tue Mar 12 22:22:27 2019 TCP connection established with [AF_INET]*****my ip*********
Tue Mar 12 22:22:27 2019 TCP_CLIENT link local: (not bound)
Tue Mar 12 22:22:27 2019 TCP_CLIENT link remote: [AF_INET]*****my ip*********
Tue Mar 12 22:22:27 2019 [server] Peer Connection Initiated with [AF_INET]*****my ip*********
Tue Mar 12 22:22:39 2019 open_tun
Tue Mar 12 22:22:39 2019 TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{319F348A-FC54-493B-A954-D9B0308654D6}.tap
Tue Mar 12 22:22:39 2019 Set TAP-Windows TUN subnet mode network/local/netmask = 172.16.6.0/172.16.6.10/255.255.255.0 [SUCCEEDED]
Tue Mar 12 22:22:39 2019 Notified TAP-Windows driver to set a DHCP IP/netmask of 172.16.6.10/255.255.255.0 on interface {319F348A-FC54-493B-A954-D9B0308654D6} [DHCP-serv: 172.16.6.254, lease-time: 31536000]
Tue Mar 12 22:22:39 2019 Successful ARP Flush on interface [8] {319F348A-FC54-493B-A954-D9B0308654D6}
Tue Mar 12 22:22:39 2019 do_ifconfig, tt->did_ifconfig_ipv6_setup=0
Tue Mar 12 22:22:44 2019 Warning: route gateway is not reachable on any active network adapters: 172.16.1.1
Tue Mar 12 22:22:44 2019 Initialization Sequence Completed
Tue Mar 12 22:22:58 2019 Connection reset, restarting [-1]
Tue Mar 12 22:22:58 2019 Warning: route gateway is not reachable on any active network adapters: 172.16.1.1
172.16.1.1 is not reachable from 172.16.6.10/255.255.255.0
the gateway from vpn should be 172.16.6.1 to be reacheable
Post your device config with :
export hide-sensitive
# mar/12/2019 22:41:22 by RouterOS 6.43.7
# software id = KSGP-NXQH
# model = RB4011iGS+
# serial number = AAAF0A4F1075
add name=bridge-vlan10
add name=bridge-vlan20
add name=bridge-vlan30
add name=bridge-vlan40
/interface vlan
add interface=ether10 name=vlan10-eth10 vlan-id=10
add interface=ether10 name=vlan20-eth10 vlan-id=20
add interface=ether10 name=vlan30-eth10 vlan-id=30
add interface=ether10 name=vlan40-eth10 vlan-id=40
add interface=ether10 name=vlan99-eth10 vlan-id=99
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=pool-vlan10 ranges=172.16.1.50-172.16.1.254
add name=pool-vlan20 ranges=172.16.2.50-172.16.2.254
add name=pool-vlan30 ranges=172.16.3.50-172.16.3.254
add name=pool-vlan40 ranges=172.16.4.50-172.16.4.254
add name=pool-openVPN ranges=172.16.6.5-172.16.6.10
add address-pool=pool-vlan10 disabled=no interface=bridge-vlan10 name=dhcp-vlan10
add address-pool=pool-vlan20 disabled=no interface=bridge-vlan20 name=dhcp-vlan20
add address-pool=pool-vlan30 disabled=no interface=bridge-vlan30 name=dhcp-vlan30
add address-pool=pool-vlan40 disabled=no interface=bridge-vlan40 name=dhcp-vlan40
/ppp profile
add local-address=172.16.6.4 name=openVPN remote-address=pool-openVPN use-encryption=required
add bridge=bridge-vlan30 interface=ether5
add bridge=bridge-vlan40 interface=ether3
add bridge=bridge-vlan40 interface=ether4
add bridge=bridge-vlan40 interface=ether2
add bridge=bridge-vlan30 interface=ether6
add bridge=bridge-vlan10 interface=ether8
add bridge=bridge-vlan10 interface=ether9
add bridge=bridge-vlan20 interface=ether7
add bridge=bridge-vlan10 interface=vlan10-eth10
add bridge=bridge-vlan20 interface=vlan20-eth10
add bridge=bridge-vlan30 interface=vlan30-eth10
add bridge=bridge-vlan40 interface=vlan40-eth10
add comment=defconf list=LAN
/interface ovpn-server server
set certificate=server cipher=aes128,aes256 default-profile=openVPN enabled=yes require-client-certificate=yes
add address=172.16.1.1/24 interface=bridge-vlan10 network=172.16.1.0
add address=172.16.2.1/24 interface=bridge-vlan20 network=172.16.2.0
add address=172.16.3.1/24 interface=bridge-vlan30 network=172.16.3.0
add address=172.16.4.1/24 interface=bridge-vlan40 network=172.16.4.0
add address=172.16.5.1/24 interface=vlan99-eth10 network=172.16.5.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server lease
add address=172.16.4.254 client-id=1:0:8:9b:eb:cd:d0 mac-address=00:08:9B:EB:CD:D0 server=dhcp-vlan40
add address=172.16.4.252 mac-address=B8:27:EB:6F:21:3F server=dhcp-vlan40
add address=172.16.1.0/24 gateway=172.16.1.1
add address=172.16.2.0/24 gateway=172.16.2.1
add address=172.16.3.0/24 gateway=172.16.3.1
add address=172.16.4.0/24 gateway=172.16.4.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment=OVPN dst-address=141.135.130.166 dst-port=1194 protocol=tcp
add action=accept chain=input comment=MGMT dst-address=172.16.5.0/24 dst-port=8291,80,443,22 protocol=tcp src-address=172.16.2.0/24
add action=accept chain=forward comment="TELENET ALLOW ALL OUT" out-interface=ether1 src-address=172.16.3.0/24
add action=drop chain=forward comment="TELENET DROP if outgoing is not WAN" out-interface=!ether1 src-address=172.16.3.0/24
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ppp secret
add name=pieterdu profile=openVPN service=ovpn
/system clock
set time-zone-name=Europe/Brussels
/system logging
add topics=firewall
add topics=ovpn
/tool mac-server
/tool mac-server mac-winbox
