Ovpn Issue
Problem with Ovpn
I connect correctly I am assigned an IP of the RB subnet, I can ping all the IPs of the devices in the same subnet of RB but not the devices connected to the different subnets, despite having created the static routes and the ping from the terminal responds. I have tried everything I knew to configure firewall and nat but always without success. I tried to activate the proxy-arp in the bridge always without success.
Does anyone have a solution
Probably in a moment someone will recommend you not to write novellas, but to paste your config here.
