I have this problem when I install OVPN of mikrotik, I’m doing wrong, if anyone has information on how to mount a OVPN of mikrotik, please direct me to documentation, I thank you in advance.
either change client in tun mode or set ovpn to mode=ethernet
You could make the connection with mikrotik, but I get this error,
There is a problem in your selection of --ifconfig endpoints [local=10.8.0.50, remote=10.8.0.1]. The local and remote VPN endpoints must exist within the same 255.255.255.252 subnet. This is a limitation of --dev tun when used with the TAP-WIN32 driver. Try ‘openvpn --show-valid-subnets’ option for more info.
Wed Jul 20 12:56:32 2011 Exiting
I only ip’s connected to mask 30 172.16.1.1 and 172.16.1.2 for example, but I can not use pool as it should.
Spanish:
Ya pude hacer la conexion con mikrotik, pero me sale este error, solo me conecta con ip’s mascara 30 por ejemplo 172.16.1.1 y 172.16.1.2, pero no puedo usar pool como debe ser.
