OVPN problem.
I have problem with ovpn server on routeros 3.30 (RB133).
On MAC OS (client) with openvpn 2.2.1 everything is ok.
But on WINDOWNS system (client) with openvpn 2.2.1 I have resetting connection after ARP FLUSH:
Sat Mar 31 20:34:39 2012 Successful ARP Flush on interface [25] {26B1016F-F75B-4C4A-8434-19939406F5D3}
Sat Mar 31 20:34:39 2012 Connection reset, restarting [0]
Sat Mar 31 20:34:39 2012 TCP/UDP: Closing socket
Sat Mar 31 20:34:39 2012 Closing TUN/TAP interface
Sat Mar 31 20:34:39 2012 SIGUSR1[soft,connection-reset] received, process restarting
Sat Mar 31 20:34:39 2012 Restart pause, 5 second(s)
Please help me fix this problem.
Best regards
Not enough information. There are a lot of reasons for this kind of error (soft reset). Did you look into server log, not only client? Often it helps.
Server logs:
20:09:23 ovpn,info TCP connection established from XX.XX.XX.XX
20:09:23 ovpn,info : dialing…
20:09:34 ovpn,info : using encoding - AES-256-CBC/SHA1
20:09:35 ovpn,info : connected
20:09:35 ovpn,info,account test logged in, 192.168.0.200
20:09:47 ovpn,error could not add address: local address is 0.0.0.0 (6)
20:09:47 ovpn,info,account test logged out, 12 0 0 0 0
20:09:47 ovpn,info : terminating… - could not add address: local address is 0.0.0.0 (6)
20:09:47 ovpn,info : disconnected
It was my false (add local-address to ppp secret is enough) but now I have a lot of informations:
Sat Mar 31 22:26:36 2012 TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
Sat Mar 31 22:26:36 2012 Route: Waiting for TUN/TAP interface to come up…
Sat Mar 31 22:26:37 2012 TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
Sat Mar 31 22:26:37 2012 Route: Waiting for TUN/TAP interface to come up…
Sat Mar 31 22:26:38 2012 TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
Sat Mar 31 22:26:38 2012 Route: Waiting for TUN/TAP interface to come up…
Sat Mar 31 22:26:39 2012 TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
Sat Mar 31 22:26:39 2012 Route: Waiting for TUN/TAP interface to come up…
Sat Mar 31 22:26:40 2012 TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
Sat Mar 31 22:26:40 2012 Route: Waiting for TUN/TAP interface to come up…
Sat Mar 31 22:26:41 2012 TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
Sat Mar 31 22:26:41 2012 Route: Waiting for TUN/TAP interface to come up…
Sat Mar 31 22:26:42 2012 TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down
Sat Mar 31 22:26:42 2012 Route: Waiting for TUN/TAP interface to come up…
and ip address doesn’t exist on tap interface …
Ok, problem is fixed = add “ip-win32 ipapi” to client config.
Thanks.
