Why is not the Local Address and the Remote Address displayed in my VPN?
Post the ppp secret and ppp profile parts of the config.
First, you can define a IP pool. Put this pool on profile for you ovpn server. If you want same ip for all clients on the server side, you must indicate it on Local Address. Also on remote address you must indicate pool for clients. You can indicate the same pool for local address too, so the local address will be distinct for each client (the server ip).
you put the ip on each secret definitions, for indicate specific ip for each one on both sides.
Yes, but in client not show this address. Is normal?
I checked on my MKs OVPN server and neither show ips on this control You can see local and remote IP on active conections control.
