I have a problem with the ovpn “… terminating nothing received for a while”
Sometimes i see on the client side:
ovpn-garage: terminating…: nothing received for a while
ovpn-garage: disconnected
ovpn-garage: initializing…
ovpn-garage: connecting…
ovpn-garage: using encoding - AES-256-cbc/SH1
ovpn-garage: connected
How can i prevent this ? Its a problem for my home-automation Lan-Gateway in the Garage.
Does it help to disable the keepalive-timeout on the server side ?
It’s to change clients’ addresses. Remnant from times when ISPs used to charge big money for business-grade xDSL (apart from business-grade price client received static IP address allowing them to host public servers).
i have a connection over OVPN from the Homematic System (Home Router) to a Homematic LanGateway (LTE Router in the Garage)
Every time there is a reconnect (12h due to the LTE provider) these connection (TCP, Port 2000 und 2001) stays in “established” so that there is no connection after this reconnect.
i have to reboot the LanGateway that there is a new connection.
