A previous thread had discussed disconnections and re-associations with Nstreme, particularly under load but not always.
I have also seen this problem, and have found Nstreme to be “choppy” even with a good connection. This may be at the core of the issues as I get big drops but in this case no broken links. The units I had trouble with were changed to regular 802 and the problems went away. The disassociation seem to me much more previlent with low signal and or interference.
Platform Clients MT RB411 with R52H
AP 2.2 an 4.2 are RB532 with XR5, 20.254 is RB411A with XR2 XR5’s are on the same tower.
Software 3.6 or higher
As you can see from the screen shot the non Nstreme shot is clean and solid even with more clients. The other NSteme on the same tower has a much poorer performance. This tower is in the middle of know where so there is no interference issues.
I will be sending this and the support.rif to MT.
Erik
