P2P Bit-torrent are detected but not dropped in 2.9RC9
Hi all,
With this rule I thought I blocked all P2P connection trough the router:
0 chain=forward p2p=all-p2p action=drop.
When I check in the connection table, I see allot of bit-torrent connections.
In RC6 this worked fine, but now in RC9, it don’t.
Does anyone know if this is a bug?
BR, Paul
i have the same thing on in my rc6 box.
i have thousands of connections labled as bit-torrent and i have the same firewall rule.
Is there is a better way to stop this?
I added rules to drop TCP dst-port 6881 and 6882. this seems to help.
This box had over 5500 conections on it today.
you will see these connections (better said: connection attempts) from clients, because there is no way how to stop them from TRYING to connect. If their tries are successfull, that’s another story.
I just want to say : if you see thousands of BitTorrent connections, verify whether these are just SYN packets sent from client and dropped by your server or whether these are actual live connections transferring data.
The connections are established, so it’s not only SYN packets. The connections are identified as bit-torrent, if a unchek the P2P-option the packets are dropped.
