P2P connection limiting
hi
i want to limit p2p connections but it seems that it want work??
can someone give me a rule for that?
Try to add this simple queue:
add name="Peer to Peer 128K" target-addresses=0.0.0.0/0 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 queue=default/default limit-at=0/0 max-limit=128000/128000 total-queue=default p2p=all-p2p
This queue will limit to a max of 128K all the p2p..
Regards
thanx but how can i limit the connections, like only 25 connections to p2p
Yes I like to know that too
Like this in Queues Tree I heve limitad IP 192.168.1.50 band:64000/128000
so how can I limit IP 192.168.1.50 to have avelible 20 connections
Maybe try something like:
chain=forward in-interface=Local protocol=tcp dst-port=1024-65535 connection-limit=20,32 action=drop
