hello;
this is firs post for me in this forum i hope interact with me…
i need best setting for p2p antenna dish 32db two sides and Metal 5SHPn two sides..
signal -55/-57 CCQ: 88/70
bandwidth : 33Mbps - 44Mbps
Try and disable NV2 for a while and give it a test with NStream enabled.
I have no ptp links with metals, we only use them for ptmp sectors on our smaller towers.
A suggestion, if you want more bandwidth is to replace the metals with RB912’s or BaseBox 5’s and get 2x dual chain dishes.
Ubiquiti’s Rocket Dishes works well.
