I hope this is a simple one for someone because I just can’t seem to make it work as well as it did on version 2.8.28. I am trying to limit EVERY connection to a maximum up/down rate of 40kbps. In other words, I have 300 users and I would like each users attempt at p2p to be limited to 40kbps…Here are the rules I am [trying] to use, but it seems to make p2p connections die, as well as I never see any traffic in the global-in queue when i do the command /queue tree pri byt int=1.
Can someone tell me what I am doing wrong??
ip firewall mangle add chain=forward p2p=all-p2p action=mark-connection new-connection-mark=p2p_conn;
ip firewall mangle add chain=forward connection-mark=p2p_conn action=mark-packet new-packet-mark=p2p;
queue tree add parent=global-in packet-mark=p2p limit-at=40000 max-limit=40000 priority=8;
queue tree add parent=global-out packet-mark=p2p limit-at=40000 max-limit=40000 priority=8
