Package Management - Uninstalled packages
With ROS7, are the listed uninstalled packages useable?
HAP AX3 lists 3 packages for wifi/wireless.
Can I use the -BE one and see some improvement?
No. The -be package is for wifi 7 devices with Qualcomm chips. Yours is wifi 6.
(I'm not sure if any of these fabled devices for which -be is usable have shipped yet...)
Afaik you can't install multiple wifi-* packages at the same time. And as already said, wifi-qcom-be is not compatible with AC3 wireless chipsets.
:joy:
Thanks.
Would have thought there would be some logic applied to only display what is compatible with the hardware.
Ha-ha. Nope.
