Package naming in 2.8.15
2.8.15 provides both the new wireless package including N-Streme and the “wireless-legacy” package without N-Streme.
Both show up identically under netinstall (both are named “wireless”, same version and description (which is cut so you can’t read it fully)). This makes choosing the right one impossible.
Perhaps the package name (or description) could be modified to state which wireless package it is…
Ah, yes, I also noticed that. But guessed right two times - the first one is with nstreme (and the other one then should be - without) :slight_smile:
