Hi Guys
Ive been trying to install packages but they dont reflect ( NTP and Wireless Package) Tried drag and drop and upload options nothing works.
Im using Hex lite (mipsbe) started with Vserion 6.41, then 5.26 nothing works.
Hi Guys
Hi
You need to put the packages of same version (not sure if other versiion would work) in the root directory of your router (“/”) and then restart the router.
The software can be had here: https://mikrotik.com/download
Hi Sebastia
i tried all the options in the book nothing worked.
Check the LOG section, it will explain why some package was not installed.
Thank you, im getting the following error ( 08:31:59 system,error can not install wireless@-6.39.3: system-6.39.3 is not installed, but is required )
Use the same version you run the system. Remove the wrong version files, put there the right ones and reboot.
Hi Jarda
Thanks for your assistance
Your welcome.
Aaahhhh, the magic of log files ![]()
