On the VLAN there is hardware which is manufactured by us. On sfp1 is a machine with linux, which has a configured VLAN interface.
On SFP2, 4 and 5 is our Hardware.
We have a program, which sends a large amount of packages to that hardware and logs for transfer errors.
When I send a lot of packages to a device, they arrive in a jerky manner.
That doesn’t happen with a old Netgear GS108T. With this switch it works as expected.
Any Idea what can be the cause of this or what I can do to find the cause?
CRS1xx can’t offload bridge operations to hardware, which means all manipulations are done by its general-purpose CPU. In order for switch chip to do the processing (at wirespeed), you have to reconfigure your CRS106 to use switch chip which is configured under /interface ethernet switch and subtree … according to manual examples.
Yes, I mean HW offload. What you see in column #5 is configured value. What you don’t see, are ‘H’ in column #2, showing that hardware offload is indeed active. Something like this:
(note that I replaced index numbers with interface names in /interface ethernet switch port above for better understanding of settings. The export commad has idnex numbers there).
Mind that device above is RB951G and has different configuration options (and syntax) under /interface ethernet, so you have to refer to manual page I linked in my previous post.
As explained already the CRS-1XX Series don’t support bridge hardware offloading.
From the documentation:
For example, you use this configuration on a CRS1xx/CRS2xx series device and you started to notice that the CPU usage is very high and when running a performance test to check the network’s throughput you notice that the total throughput is only a fraction of the wire-speed performance that it should easily reach. The cause of the problem is that not all devices support bridge VLAN filtering on a hardware level. All devices are able to be configured with bridge VLAN filtering, but only a few of them will be able to offload the traffic to the switch chip. If an improper configuration method is used on a device with a built-in switch chip, then the CPU will be used to forward the traffic.
Create a single default bridge and add all your interfaces to it. Now use the Switch Menu to configure your VLANs as per the link @mkx already posted.
If a wan’t to have a port with a tagged VLAN 1337 but also as a untagged Port for the default VLAN (0 I think)…how do I have to configure this? Do I have to create a VLAN 0 in the switch section?
And How do I have to set the ingres and egress vlan tags?
The untagged VLAN is tretated slightly differently by different switch chips. I suggest you to go “all-tagged”. Which means you have another VLAN used internally and have ports, that should be untagged externally, configured as access ports to that VLAN. This can also serve as future proof config in case you decide to connect your untagged VLAN via some trunk connections to another switch.
When selecting VLAN ID for “untagged VLAN”: 0 is illegal value (legal VLAN ID numbers are from 1 to 4094), you could go for 1 which is used implicitly in ROS (and by some other vendors) but due to implicit config all over the place it may give some problems. So I suggest you to avoid ID 1 (mind that there’s nothing wrong with using VID 1 … if you manage to change config everywhere that’s needed).
Then you’d go something like this:
add name=bridge # normally there will only be one bridge per switch ... functions of second and further bridges can not be offloaded to hardware
add bridge=bridge interface=ether6 hw=yes # add all the ports that are used to connect same (V)LANs, normally this means all of ports
/interface ethernet switch ingress-vlan-translation # this section is about untagged ports (or hybrid ports for untagged part)
add ports=ether6 customer-vid=0 new-customer-vid=666 # or whatever ID you select for "untagged VLAN" and whatever ether port you want to be a hybrid port
/interface ethernet switch egress-vlan-tag # this section is about tagged ports (or tagged part of hybrid ports)
add tagged-ports=ether6 vlan-id=1337
/interface ethernet switch vlan # this section is about all VLANs, both tagged and untagged
add ports=ether6 vlan-id=1337
add ports=ether6 vlan-id=666
Repeat hte configuration regarding ether6 for all other ports according to wanted config.
If you want switch to interact with untagged VLAN (e.g. if it’s your management vlan at the same time), then you have to add some config to make bridge interface part of that VLAN. I suggest you to make it tagged member of said VLAN:
# this code block replaces some of config and adds some to the code block above
add tagged-ports=switch1-cpu vlan-id=666
set [ find vlan-id=666 ] ports=ether6,switch1-cpu # make sure the port list is complete ... you can not "add" a port to already existing list
/interface vlan
add interface=bridge name=vlan666 vlan-id=666
Then you normally use interface vlan666 as interface having switch’s IP address assigned etc. (instead of bridge if it was simple switch without VLANs or a physical interface (e.g. ether6) if the physical interface was exclusively dedicated to management of device).
You would similarly go if management was done over tagged VLAN …
I’m not sure if config, posted in original post, is still vaild. So I can not commento n your observation. But generally ROS device will try to route between all of interfaces with IP address configured unless there are firewall rules blocking such communication. In configuration from original post tehre are two interfaces with IP addresses set: bridge _interface_with IP address 192.168.88.3/24 and vlan1337 interface with IP address 194.120.11.252/22 and no firewall rules that might block communication between these two interfaces.
When CRS is used as a swtich with multiple VLANs passing between ports, switch does not need /interface vlan interface for switching functionality. A switch only needs single interface with IP address set and that should be used only for management of the switch.
If you want to get some more concrete help with your configuration, post actual configuration (again) - and we’ll tear it apart
I have no “current config” so far.´The bare board of the switch is build into our hardware. And to have a chance to configure ist, we only put a “default config” on it, which made it possible to talk to the board and protect it with a password.
The config I posted first was our “first try” (with some help from here) to get a working VLAN solution. But with this config we have the problem of the stucking when transfering a large amount of packages.
What we need:
Combo1: the “normal” network packages (I think its VLAN-ID 0). Via this device, the Switch is reachable from the lan.
SFP1: “normal” network traffic (VLAN-ID 0) PLUS tagged VLAN-Packages with VLAN-ID 1337
SFP3: Untagged packages of VLAN-ID 1337, incomming packages must be tagged with VLAN 1337
SFP4: Untagged packages of VLAN-ID 1337, incomming packages must be tagged with VLAN 1337
SFP5: Untagged packages of VLAN-ID 1337, incomming packages must be tagged with VLAN 1337
Management Interface should be available via the VLAN 1337, IP 192.168.0.239 (old default IP of the netgear switches we build in before)
Thats all I think.
With the old netgear GS108T it was no problem, simply some clicks. Now to get the same result with the Mirkotik it costs me weeks. So I’m a bit frustrated
Perhaps somebody else will chime in. I don’t want to give you full config for your device because
I don’t own a CRS1xx so I can’t be 100% sure my config would be correct
I’m willing to aide with learning how to use Mikrotik devices but I’m not a consultant (even less a paid one)
So if you’re unable to work from the “first try” config you posted and through suggestions I already provided (and some other might add some suggestions), then you probably have to get some consultant to do the job for you. Or get switch(es) from some other vendor which have easier management UI.
The Schema I gave you is not what we use outside.
Its a setup here in my office to play and to learn with.
The final config I will do by myself. I only need a hook to hang on…
We delivered already switches with a config which works basically, but not at high loads.
Thats my config so far, seems to work as I expected. Didn’t test it under load untill now.
The only thing I miss atm. is how to get the management interface available via the vlan 1337
Substitute x.y.z.w with actual IP address you want to use when managing switch. If it’s one of already assigned IP addresses, then you’ll have to deassign that address first (and make sure you’re doing it while connecting to switch using the other IP address … or by connecting via MAC using winbox).
After you verify you can actually connect to the newly set-up management IP address, remove all other IP addresses. If at this point communication between LAN devices ceases to flow, then CRS was actually routing traffic and CRS1xx is a very low-capacity router (if configured as such).
Other options you can try:
remove combo1 port from bridge. If you need this port as local management port, configure IP address directly on port.
In theory combo1 is part of switch chip and should work just like the other ports, but since it’s combo, who knows.
what kind of SFP modules are you using, optical ones? If so, take extra care to have connectors clean (both cable side as well as SFP side).
Dirty fibre connections can cause packet drops which in turn cause all sorts of problems with data transfer (either excessive retransmissions which translates to jerky transfer speeds or even dropped contents in case when retrasmissions are not part of transport protocol - multicasts and UDP don’t offer retrasmissions on transport layer).
If you’re using RJ45 SFP modules, check if they are on compatibility list. MT devices can be quite picky about which SFP modules … and that’s true both for RJ45 modules and optical modules.
