I maked an EoIP tunnel, und tried to disable DHCP and File Sharing and Network Printers protocolls in tunnel, but it wasn’t successfull.
Is it possible anyway?
Have somebody an idea?
Yes it is possible. How did you try doing it? What specific rules?
Make sure the rules are being applied on the EoIP interfaces themselves and not on the ethernet port the traffic is being encapsulated out over.
Since you most likely have your EoIP tunnel as part of a bridge group, did you enable IP filtering on the bridge and use the bridge firewall?
http://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#Bridge_Firewall
