Hi there,
it has been a while
I’m reviewing my firewall rules and have some hiccups grasping all again.
I asked myself quite a basic question but my mind was filled with other things, so I would like to have a second opinion on it.
How often will a package flow through this before it hits www (or my ISP) if I have VLANs and Bridge
If I combine
from Manual:Packet Flow - MikroTik Wiki | 4.3 Vlan Untagging/Tagging in the bridge interface and the Routing Packet Flow Diagram from firewall vs nat packet flow - MikroTik
it is only once, isn’t it?
Simplified it is:
- From host to Interface on router (VLAN trunk / tagged port is the physical in)
- Then Decapsulation takes place
- Afterwards it goes to the Logical In Interface, the respective VLAN Interface
- Then, it is forwarded to the physical WAN interface where it leaves the router with any other processing on the router anymore
