I got one situation that makes me confused. I’m using RouterOS 5.24
According to Traffic flow diagram on Mikrotik Wiki packet destined to MT goes first into INPUT chain (Mangle Input → Filter Input) then into Prerouting chain if interface is not bridged. Here is the simplified example of the conflict situation:
I got this rule in Filter Input chain:
chain=input action=drop protocol=tcp dst-address=1.1.1.1 dst-port=22
where 1.1.1.1 is “public” address on my interface.
If input interface is not bridged packet goes to Prerouting interface, then in Destination NAT chain where I got this rule:
chain=dstnat action=dst-nat to-addresses=192.168.1.2 to-ports=22 protocol=tcp dst-address=1.1.1.1 dst-port=22
The problem is that filter rule should block every packet on port 22, because Filter Input chain is before Destination NAT. After I disable rule in Dest. NAT chain then filter rule “capture” the packet, that is, it block the packet on port 22.
Why is this happening?
mIRO
