Packet loss between two bridges
I’ve bought Microtik recently, so I’m a new user, however I think my issue is not so beginner.
I have a strange packet loss, it is not random, usually every 6th packet is lost. Sometimes it come back with delay (900ms, 1600ms), but usually it’s lost completely. After reboot pings work for some time without issues.
  1. I’m pinging 10.0.0.10 from 192.168.3.100
  2. 10.0.0.10 drops no pings when pinged from 10.0.0.0/16 or from device.
Any ideas are welcome.
# nov/07/2019 22:48:26 by RouterOS 6.45.7
# software id = 04PU-E3UT
# model = RB760iGS
# serial number = *snip*
add admin-mac=74:4D:28:F0:95:A6 auto-mac=no comment=defconf fast-forward=no name=inside protocol-mode=none
add fast-forward=no mtu=1500 name=wifi protocol-mode=none
set [ find default-name=ether1 ] mac-address=00:16:C7:FA:0F:F4
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=WIFI
/ip hotspot profile
/ip ipsec peer
add address=*snip*/32 exchange-mode=ike2 name=*snip*
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 proposal-check=exact
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-cbc pfs-group=none
add name="inside pool" ranges=10.0.0.100-10.0.0.200
add name="wifi pool" ranges=192.168.3.100-192.168.3.200
add address-pool="inside pool" disabled=no interface=inside name=defconf
add address-pool="wifi pool" disabled=no interface=wifi name="wifi server"
add bridge=inside comment=defconf interface=ether2
add bridge=inside comment=defconf interface=ether3
add bridge=wifi comment=defconf hw=no interface=ether4
add bridge=wifi comment=defconf hw=no interface=ether5
add bridge=inside comment=defconf hw=no interface=sfp1
add comment=defconf interface=inside list=LAN
add interface=wifi list=WIFI
add address=10.0.0.222/24 comment=defconf interface=inside network=10.0.0.0
add address=192.168.3.222/24 interface=wifi network=192.168.3.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1 use-peer-dns=no
add address=10.0.0.0/24 comment=defconf gateway=10.0.0.222 netmask=24
add address=192.168.3.0/24 dns-server=109.195.80.1,109.195.81.1 gateway=192.168.3.222
set allow-remote-requests=yes servers=10.0.10.1
/ip dns static
add address=10.0.0.222 comment=defconf name=router.lan
/ip firewall address-list
add address=10.0.0.0/16 list=local
add address=10.0.0.10 list=printer.home
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="local device access" dst-address=10.0.0.222 dst-port=80 protocol=tcp src-address-list=local
add action=accept chain=input dst-port=53 in-interface-list=LAN protocol=tcp
add action=accept chain=input dst-port=53 in-interface-list=LAN protocol=udp
add action=drop chain=input comment="default input rule" log=yes
add action=accept chain=forward comment="allow access to printer" dst-address-list=printer.home in-interface-list=WIFI
add action=drop chain=forward comment="disallow access from wifi" dst-address-list=local in-interface-list=WIFI
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=srcnat dst-address=0.0.0.0/0 log=yes src-address=10.0.0.0/24
/ip ipsec identity
add auth-method=digital-signature certificate=*snip* peer=*snip*
/ip ipsec policy
set 0 disabled=yes
add action=none dst-address=10.0.0.0/24 src-address=10.0.0.0/24
add action=none dst-address=192.168.3.0/24 src-address=10.0.0.0/24
add dst-address=0.0.0.0/0 peer=*snip* sa-dst-address=*snip* sa-src-address=0.0.0.0 src-address=10.0.0.0/24 tunnel=yes
add dst-address=10.0.10.1/32 peer=*snip* sa-dst-address=*snip* sa-src-address=0.0.0.0 src-address=10.208.125.234/32 tunnel=yes
/system clock
set time-zone-name=Europe/Moscow
/system identity
set name=*snip*
/tool mac-server
/tool mac-server mac-winbox
You haven’t stated whether, at the 192.168.3.0/24 subnet / “wifi” bridge side, the pinged devices are connected using a wire or wirelessly, and how do they respond to pings from 192.168.3.222 (the Tik itself).
The problem may be in the routing on the Tik itself, in the bridging on the Tik itself, in the wireless AP connected to the Tik, in the cable between the Tik and the wireless AP… So the right thing to do is to split the path into small portions and investigate them as separately as possible. Running /interface ethernet print stats interval=1s while pinging and watching for the various error counters (rx-fcs-error and maybe others) may help you identify cable issues, and running tool sniffer quick ip-address=x.x.x.x ip-protocol=icmp will show you whether the ICMP echo requests and responses are being forwarded (routed) from one interface to another.
Thank you for your reply. I’ve almost lost any hope that my topic was noticed.
I did everything that you suggested and I think, the problem is in printer device itself (10.0.0.10). It reliably dropping some packets when pinged outside of it’s network. Yes, I know it’s very confusing, but it happens with my old router as well. As minor packet loss is not affecting it’s printing capabilities, I leave it as is.
