Packet loss from antenna to routerboard on cable link
Hello, I have one antena Omnitik Connected as the picture attached
The antenna (AP1) is not replying to R2 neither R1 but AP2 is replying ok. ETH3 is slave from ETH2 and both are bridged to ETH1. The wear part is that if i disconnect AP1 to the network and connect a laptop with the same cable, it start working.
Any idea?
Please paste R2 and AP1 configuration with status of all ethernet ports for both units.to find out the problem
regards
digging something i found this.
When the port eth1 on R2 is in the bridge I can reach AP2 but not AP1. When the eth1 is not in the bridge mode i can ping AP1 but not AP2.
Any idea?
Some info about the cable you are using maybe?
Cable UTP cat 6
