Packet loss when using ipsec on the mmips platform
Hello.
I have a problem with packet loss when using Site-To-Site IPSEC VPN on the MMIPS platform with RouterOS version 6.48.10 (long-term).
Connection diagram: PC1 - network - MikroTik hEX - internet - Cisco ASA - network - PC2
All packets from PC2 come to PC1.
I checked the transmission of ICMP packets from PC1 using ping, flood ping - all packets reach the destination. UDP packets are also fine. Perhaps there were not enough packets.
When I start sending TCP packets from PC1, about half of the packets reach their destination.
Very interesting: when I turn on Packet Sniffer on MikroTik hEX, the destinations reach all 100% of the packets.
Can someone help me with the problem?
Make sure you do not fasttrack the inner-tunnel traffic. Perhaps just try disabling all fasttrack rules first and see if it helps.
Thanks. The range of addresses behind the tunnel was included in the fasttrack rule.
It works now.
