OK, I don’t know what the problem is, so I’ll just explain what I did.
AP is running ver 2.9.48 on 112 board, Ubiquiti SR5 radio. Client is running ver 3 RC9, on board 133c, R52 radio. 5Ghz band, 5180 MHz
It feels slow, if you do a ping you see many time outs.
So, we downgrade the client to 2.9.48 remotely (he’s 120 Km away, so I really don’t what to drive there) and live is beautiful again, it feels much faster, says the client and no time outs at all when pinging.
So, with 2.9.48, it works not with 3 RC9, WHY??? Are there any default parameters that change from one version to another? Any setting that I could change on the ver 3 RC9 that would make it perform as the 2.9.48? (on the wireless links I would assume.
That’s simple, because I bougth 6 RB 333 to be used as AP, but they give me so many problems that I rather use the 112.
I’m 99% sure that it’s a software/config problem, because I can only use ver 3 x on the 333s. Using 2.9 gives me no problems on any hardware, this is the reason I’m writing in this forum!
For now, I’m buying 532s only to replace the 333s, with high hopes that this issue posted before is fixed, or that least someone tells me a way around it.
Maybe there is no way around it, maybe I’m the only one in the world that has a 100 Km link working fine on 112s with 2.9 but has erratic behavoir after upgrading to 3 RCx on RB 333s… and that is why nobody has noticed this…
The other 333s that I have seem to work fine on short links, say less than 10 Km, but above that, forget it.
