Hello, I’m having issues with packet marks. as in, they’re not marking packets.
Currently i have rule setup to mark any packet from the ip address 192.168.135.199 with 768d.
and I have a queue setup to limit anything with a packet mark of 768d to 768k.
My problem is when i start downloading, the packet mark counter doesn’t do much at all, downloaded over 400mb and it says its marked less then 16mb. needless to say, the download wasn’t limited.
(side note, we use PCC to balence 4 DSL connections, with some rules to send some traffic from some hosts over a static DSL line)
Here’s my cfg.
TIA
Mangle
/ip firewall mangle
add action=mark-connection chain=input comment="" disabled=no in-interface=\
pppoe-out1 new-connection-mark=wan1_conn passthrough=yes
pppoe-out2 new-connection-mark=wan2_conn passthrough=yes
pppoe-out3 new-connection-mark=wan3_conn passthrough=yes
pppoe-out4 new-connection-mark=wan4_conn passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wan1_conn \
disabled=no new-routing-mark=to_wan1 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wan2_conn \
disabled=no new-routing-mark=to_wan2 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wan3_conn \
disabled=no new-routing-mark=to_wan3 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=wan4_conn \
disabled=no new-routing-mark=to_wan4 passthrough=yes
add action=mark-connection chain=prerouting comment="" disabled=no \
dst-address-type=!local in-interface=ether1 new-connection-mark=wan1_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/0
dst-address-type=!local in-interface=ether1 new-connection-mark=wan2_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/1
dst-address-type=!local in-interface=ether1 new-connection-mark=wan3_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/2
dst-address-type=!local in-interface=ether1 new-connection-mark=wan4_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:4/3
add action=mark-routing chain=prerouting comment="" connection-mark=wan1_conn \
disabled=no in-interface=ether1 new-routing-mark=to_wan1 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=wan2_conn \
disabled=no in-interface=ether1 new-routing-mark=to_wan2 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=wan3_conn \
disabled=no in-interface=ether1 new-routing-mark=to_wan3 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=wan4_conn \
disabled=no in-interface=ether1 new-routing-mark=to_wan4 passthrough=yes
add action=mark-packet chain=prerouting comment="User 768D" disabled=no \
new-packet-mark=768d passthrough=no src-address=192.168.135.199
add action=mark-connection chain=prerouting comment=Test disabled=no \
dst-port=8080 in-interface=ether9 new-connection-mark=SSL2 passthrough=\
yes protocol=tcp
add action=mark-connection chain=prerouting comment=\
"Moves SSL connections to PPPoE_1" disabled=no dst-port=443 in-interface=\
ether1 new-connection-mark=SSL passthrough=yes protocol=tcp
"For Jan Tidus' Internet banking. Marks Connection" disabled=no \
in-interface=ether1 new-connection-mark=SSL passthrough=yes \
src-mac-address=00:15:6D:F8:18:11
"Burns Mark Connection -> SSL" disabled=no in-interface=ether1 \
new-connection-mark=SSL passthrough=yes src-mac-address=00:15:6D:FA:D7:51
add action=mark-connection chain=prerouting comment=Chophouse disabled=no \
new-connection-mark=LocksMill passthrough=yes src-mac-address=\
00:15:6D:FA:5E:C7
add action=mark-connection chain=prerouting comment="Laptop IN Office" \
disabled=no new-connection-mark=Sonicwall passthrough=yes src-address=\
192.168.135.199
"For the office Firewall marks connection" disabled=no in-interface=\
ether1 new-connection-mark=Sonicwall passthrough=yes src-mac-address=\
00:06:B1:2F:A6:C1
"Locks Mill HLS. Marks Connection" disabled=no in-interface=ether1 \
00:15:6D:E6:A8:6D
add action=mark-connection chain=prerouting comment="Wes Scheulen" disabled=\
no in-interface=ether1 new-connection-mark=SSL passthrough=yes \
src-mac-address=00:15:6D:FA:5D:BE
add action=mark-connection chain=prerouting comment=http://my.agristar.net/ \
disabled=no dst-address=208.81.96.1 new-connection-mark=Sonicwall \
passthrough=yes
add action=mark-routing chain=prerouting comment=\
"Moves connection to PPPoE_2" connection-mark=Sonicwall disabled=no \
"Moves connection to PPPoE_3" connection-mark=LocksMill disabled=no \
"Moves connection to PPPoE_4" connection-mark=SSL disabled=no \
add action=mark-routing chain=prerouting comment=Test2 connection-mark=SSL2 \
disabled=no in-interface=ether9 new-routing-mark=to_wan3 passthrough=yes
Queue
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 \
max-limit=20M name=Download-All parent=ether1 priority=8
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 \
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=\
5
add kind=pcq name=PCQ_Down pcq-classifier=dst-address pcq-limit=50 pcq-rate=\
768000 pcq-total-limit=2000
set default-small kind=pfifo name=default-small pfifo-limit=10
/queue simple
add burst-limit=256k/512k burst-threshold=128k/256k burst-time=10s/10s \
comment="Laren Haslag" direction=both disabled=no dst-address=0.0.0.0/0 \
interface=all limit-at=0/0 max-limit=128k/256k name="Laren Haslag" \
parent=none priority=8 queue=default-small/default-small \
target-addresses=192.168.135.112/32 total-queue=default-small
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment=\
"TerryBelle Wolfe" direction=both disabled=no dst-address=0.0.0.0/0 \
interface=all limit-at=0/0 max-limit=128k/512k name="TerrieBelle Wolfe" \
target-addresses=192.168.135.30/32 total-queue=default-small
add burst-limit=512k/1M burst-threshold=0/0 burst-time=10s/10s comment="" \
direction=both disabled=no dst-address=0.0.0.0/0 interface=all limit-at=\
0/0 max-limit=256k/768k name=queue4 parent=none priority=8 queue=\
default/default target-addresses=192.168.135.168/32 total-queue=\
default-small
add burst-limit=256k/768k burst-threshold=128k/512k burst-time=10s/10s \
comment="Freedom Products" direction=both disabled=no dst-address=\
0.0.0.0/0 interface=all limit-at=0/0 max-limit=128k/512k name=\
"Freedom Products" parent=none priority=8 queue=\
default-small/default-small target-addresses=192.168.135.33/32 \
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment="Solid Rock" \
0/0 max-limit=256k/768k name="Solid Rock" parent=none priority=8 queue=\
default-small/default-small target-addresses=192.168.135.50/32 \
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment="" \
0/0 max-limit=128k/384k name="Cathay Branson" parent=none priority=8 \
queue=default-small/default-small target-addresses=192.168.135.68/32 \
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=768k \
max-limit=1M name="User 768d" packet-mark=768d parent=Download-All \
priority=2 queue=PCQ_Down
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
set ether6 queue=ethernet-default
set ether7 queue=ethernet-default
set ether8 queue=ethernet-default
set ether9 queue=ethernet-default
set pppoe-out1 queue=default
set pppoe-out2 queue=default
set pppoe-out3 queue=default
set pppoe-out4 queue=default
