packet mark, NAT works Firewall isnt
i created a set of mangle rules with layer7 content to drop acces to specific sites.
packets are marked, now im trying to setup a drop rule for firewall, and it just plainly doesnt work.
but if I setup NAT rule with the same packet mark the dns request fails (which is what im trying to do)
And yes, default fasttrack rule is disabled
So, this rule WORKS
[admin@faerun] > ip/firewall/nat/print
Flags: X - disabled, I - invalid; D - dynamic
19    chain=dstnat action=dst-nat to-addresses=0.0.0.0 packet-mark=philips_packet log=no log-prefix=""
But this doesnt (also including higher rules for context, the rule in question is 6)
[admin@faerun] > ip/firewall/filter/print
 0    ;;; defconf: accept established,related,untracked
      chain=input action=accept connection-state=established,related,untracked
 1    chain=input action=accept protocol=icmp src-address-list=vlan1 in-interface=bridge log=no log-prefix=""
 2    chain=input action=accept protocol=tcp src-address=X.X.X.0/24 in-interface=ether1 dst-port=80 log=no log-prefix=""
 3    chain=input action=accept src-address=X.X.X.130 log=no log-prefix=""
 4 X  chain=input action=accept src-address=192.168.9.0/24 log=no log-prefix=""
 5    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid
 6    chain=output action=drop packet-mark=philips_packet log=no log-prefix=""
Mangle and layer 7 rules
[admin@faerun] > ip/firewall/layer7-protocol/print
Columns: NAME, REGEXP
#  NAME            REGEXP
1  philips update  nettvservices.com
[admin@faerun] > ip/firewall/mangle/print
 2    chain=prerouting action=mark-connection new-connection-mark=philips passthrough=yes layer7-protocol=philips update protocol=udp connection-mark=no-mark
      dst-port=53 log=no log-prefix=""
 3    chain=prerouting action=mark-packet new-packet-mark=philips_packet passthrough=yes connection-mark=philips log=no log-prefix=""
You mixed everything up, you classify the traffic by DNS string, so it always marks your connections to the DNS server.
It’s easier to do this through the local DNS cache.
/ip dns set allow-remote-requests=yes
/ip dns static add address=127.0.0.1 name=philips.com type=A
/ip firewall nat add action=redirect chain=dstnat dst-port=53 in-interface-list=LAN protocol=udp to-ports=53
No, it doesnt. Other dns requests work fine even with NAT rule enabled
It still doesnt explain why firewall drop rule isnt working
Make test rule:
/ip firewall mangle add action=add-dst-to-address-list address-list=al_WEB_philips chain=prerouting layer7-protocol=philips
& look to /ip/firewall/address-list
It might explain this to you.
I tested and got my router local address in the list
So you’re basically saying that this guy is wrong? https://youtu.be/3LmQYIQ5RoA?t=467
It looks like an official Mikrotik channel
and this too:
change
chain=forward action=drop packet-mark=philips_packet log=no log-prefix=""
I tried with forward first, it doesnt work either way.
All right, i got it, forgot the input drop rule, thanks for your help.
If you are trying to block IPs, then use firewall rules.
If you are trying to block by domain name aka popular sites you are wasting your time.
