packet sniffer and filter (v2.8)
I’m trying to use the packet sniffer just to monitor DHCP traffic, but it doesn’t seem to work right.
If I understand the manual correctly I should be able to specify the following to sniff only dhcp traffic :
filter-protocol ip-only
filter-address1 0.0.0.0/0:67-68
filter-address2 0.0.0.0/0:67-68
However, when I try this the packet sniffer catches every single packet and appears to ignore the filtering.
If im not too tired right now - I believe dhcp is not ip … arp is its own protocol. You need to packet sniff all frames i believe.
Sam
Sam, you are tired. DHCP is a UDP protocol.
Yep, you are correct. I think I was too sleepy : )
Sam
