I am using a CCR1072 with ROS 6.45.7, and I noticed that after 45 minutes, Packet Sniffer stops streaming packets to the preset server, although in Winbox it still indicates that it is “running”. The same happens if I select a file instead of streaming.
Can someone tell me if this is the “expected” behavior, or this is a bug? Maybe the packet sniffer tool is not designed to be used for relatively long captures. In this case, can someone tell me what other options do I have with ROS? The amount of data I need to capture is really small (100-200MB a day, all of it is signalling), but the capture might need to run for a week or so.
Thanks! I already set up the “sniff TZSP” mangle rule. My only problem is that the output is “half sided”. It means I receive only one direction of the packets (the incoming direction). How can I set this up to get the full bidirectional traffic? The protocol is SCTP by the way.
