It’s my first time to use RouterOS.
I got few problem with forward packet via route.
Here is my topology
I did not set any rule in ip/firewall.
My IP route in routerOS is like following
Dst. Address | Gateway
0.0.0.0/0. | 10.10.10.254
10.10.10.1/24| ether1 reachable
20.20.20.0/24| ether2 reachable
The ip route in Ethernet6 is like following
default via 20.20.20.1 dev Ethernet6
20.20.20.0/24 dev Ethernet6
Now RouterOS can ping to Ethernet5(30.30.30.1/24) with src IP 10.10.10.1, but I can not ping to Ethernet5 from Ethernet6(20.20.20.10/24)
Is that right? In my thought the packet from Ethernet6(dst:30.30.30.1, src:20.20.20.10, ICMP) should arrive RouterOS and forwarding to Ethernet4.
However I did not see that packet in Torch with Ethernet1, instead I see a packet(dst:20.20.20.10, src:30.30.30.1, ICMP)… It’s strange… -
When I ping from Ethernet1 to Ethernet5 (dst:30.30.30.1, src:10.10.10.1, ICMP), I got ICMP reply successful but I do not see any ICMP request/reply packet in Torch with Ethernet1. Is that normal?
Pleas give me some comment or idea. Thanks.
