PacketFence with Mikrotik
Hello Gurus,
Please i want to find out if any one has use Mikrotik with PacketFence, could shear how this could be done? thanks in advance
you don’t need PackerFence, as RouterOS already does all the same things. You only need RouterOS
PacketFence is a NAC solution, which RouterOS doesn’t do.
Don’t know if PacketFence works with RouterOS out of the box, though. It’s all SNMP/CLI based, so it could be extended. It can recognize RouterOS DHCP servers, so maybe there’s more integration than just that.
I think you have to loose routerOS and switch to openwrt to use packetfence… too bad… But Packetfence is awesome.
