Packetloss on ethernet ports - Vlan
Hi
I have an RB1200, running a vlan (id20) on ethernet 6 (192.168.16.1)
Ethernet 6 is connected to a basic switch which feeds 3 x RB411 (192.168.16.3,11,12)
Each RB411 has the vlan set up also , and pinging between the units works - but not very well.
Im getting these results:
4 bytes from 192.168.16.3: icmp_seq=893 ttl=61 time=125.515 ms
64 bytes from 192.168.16.3: icmp_seq=894 ttl=61 time=139.392 ms
64 bytes from 192.168.16.3: icmp_seq=895 ttl=61 time=115.440 ms
64 bytes from 192.168.16.3: icmp_seq=896 ttl=61 time=104.395 ms
Request timeout for icmp_seq 897
Request timeout for icmp_seq 898
Request timeout for icmp_seq 899
No sense to it, just starts, stops, Im pinging across a PPTP tunnel in this example, but pinging from an RB411 to the RB1200 yields the same issues.
Ive removed the switch in between - same issues. Gut feeling is that its something to do with ARP.
RB411s are running versions 5.6 , 5.7 and 5.8 (trying to track the issue to a fw version). The RB1200 is on 5.7 at present but have just downloaded 5.11 but am unable to upgrade until the user have signed off.
Can anyone shed any light?
UPDATE: Upgraded RB1200 to 5.11
64 bytes from 192.168.16.3: icmp_seq=198 ttl=61 time=69.316 ms
64 bytes from 192.168.16.3: icmp_seq=199 ttl=61 time=74.872 ms
64 bytes from 192.168.16.3: icmp_seq=200 ttl=61 time=82.696 ms
64 bytes from 192.168.16.3: icmp_seq=201 ttl=61 time=68.409 ms
64 bytes from 192.168.16.3: icmp_seq=202 ttl=61 time=73.260 ms
64 bytes from 192.168.16.3: icmp_seq=203 ttl=61 time=97.189 ms
Request timeout for icmp_seq 204
Request timeout for icmp_seq 205
Request timeout for icmp_seq 206
Request timeout for icmp_seq 207
Request timeout for icmp_seq 208
Request timeout for icmp_seq 209
Request timeout for icmp_seq 210
Request timeout for icmp_seq 211
Request timeout for icmp_seq 212
Request timeout for icmp_seq 213
Request timeout for icmp_seq 214
Request timeout for icmp_seq 215
Request timeout for icmp_seq 216
Request timeout for icmp_seq 217
Request timeout for icmp_seq 218
Request timeout for icmp_seq 219
Request timeout for icmp_seq 220
Request timeout for icmp_seq 221
Request timeout for icmp_seq 222
Request timeout for icmp_seq 223
Request timeout for icmp_seq 224
Request timeout for icmp_seq 225
Request timeout for icmp_seq 226
Request timeout for icmp_seq 227
Request timeout for icmp_seq 228
Request timeout for icmp_seq 229
Request timeout for icmp_seq 230
64 bytes from 192.168.16.3: icmp_seq=231 ttl=61 time=68.161 ms
64 bytes from 192.168.16.3: icmp_seq=232 ttl=61 time=68.428 ms
64 bytes from 192.168.16.3: icmp_seq=233 ttl=61 time=97.618 ms
64 bytes from 192.168.16.3: icmp_seq=234 ttl=61 time=68.806 ms
64 bytes from 192.168.16.3: icmp_seq=235 ttl=61 time=69.973 ms
64 bytes from 192.168.16.3: icmp_seq=236 ttl=61 time=70.212 ms
64 bytes from 192.168.16.3: icmp_seq=237 ttl=61 time=97.194 ms
no joy, still random packet loss.
Seems to be consistant in that every RB411 has packet loss when pinging either another RB411 or the Rb1200
Another update:
If I leave the system alone for a while, it always takes 7 response timed outs, then on the 8th it starts pinging. No pattern evident though on the starts and stops once its started to respond.
tell this to support and send .rif file to support.
