Detect-internet was somehow enabled which lead to spamming DNS requests on one of the WAN interfaces.
Thing is, because this is a completely restricted backup WAN connection, there are firewall rules on the output chain that block all traffic apart from specific whitelisted traffic.
chain=input: traffic for which router itself is end destination
chain=output: traffic generated by router itself
chain=forward: traffic passing router in any direction. Mind that firewall has no notion of which side is “in” and which is “out” … with default firewall filter rules this distinction is made by extensive use of interface lists, by default there are lists “LAN” and “WAN”.
And keep in mind that there’s an implicit “action=accept” at the end of all rules so if you want to block some traffic, you need to block it explicitly using some more or less specific firewall rule.
Also be sure you understand the meaning of _src-_address VS _dst-_address in a given context. (A hint: it’s about the contents of IP header of a packet examined by firewall rule, doesn’t have anything to do with imaginary direction of a whole connection). The only part where whole connection context gets into play is if firewall filter rule contains connection-state=XXX.
So if the DNS traffic hitting the backup WAN Line originates from the router itself, then use of “chain=output” is correct. If the traffic is generated by some other device which communicates with backup WAN via MT, then “chain=forward” is the correct one.
BTW, option “detect internet” is largely useless and it’s best to disable it unless you fully understand what it’s good for and what are related bells and whistles.
We don’t ever use detect-internet feature, not sure how it got enabled.
I’ve posted my firewall rules, at least those related to this interface, and as you can see there are a bunch of accept rules for things we need working and then a drop rule to take care of the implicit accept.
But, it seems that the detect internet rules somehow bypass the firewall. Sniffing on ether3 I can see traffic being sent (and received but I’m not firewallling input chain) which should normally be blocked by the filter rules.
Note there’s also a drop rule for everything on the forward chain out this specific interface too, which I didn’t include in my post.
So you’re saying that is should be going through the firewall, as with any traffic generated, correct?
