Packets escape NAT?
Hello all.
I have:
AP
10.1.2.1/24 (uplink to default gateway)
10.1.3.1/24 (AP)
No mangle, NAT rules
CPE
10.1.3.2/24 (WAN/PUBLIC)
192.168.0.1/24 (LAN, masqueraded)
However, if I do this in firewall filter(on AP):
0 chain=forward action=drop connection-state=invalid
1 chain=forward action=log src-address=192.168.0.0/24 log-prefix=“”
Then I get many many log entires for TCP traffic from 192.168.0.xxx (not supposed to happen!) and if I trace the src-mac, it comes from CPEs with masquerade…
If it was ‘invalid’ packets, then rule 0 should drop it, but it doesn’t, I get 100’s of logs entries in a minute generated by rule 1.
How is this possible, how can:
  1. TCP/IP Packets arrive from behind a masquerade rule that has original IP in it?
  2. Drop invalid packets filter rule does not drop these.
  3. Packets route through all default gateways, even if there is no route for that subnet and obviously no return route?
If it is a bug that these packets ‘escape’ NAT, then at least I’d like to stop them.
To put rules on ingress for each possible subnet behind NAT is not really a good solution, I’d like to be able to stop it at the CPE so the network never receives these ‘invalid’ packets.
Regards
UPDATE:
Strange thing…
In Winbox the NAT rule looked normal, like it should be.
But for some reason I viewed it in terminal and noticed this:
[admin@Stander] /ip firewall nat> pr
0 chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=public
[admin@Stander] /ip firewall nat> rem 0
[admin@Stander] /ip firewall nat> add chain=srcnat out-interface=public action=masquerade
0 chain=srcnat action=masquerade out-interface=public
This seems to solve my problems… not!
After a reboot, the to-address=0.0.0.0 comes back and I see bunch of invalid traffic going through to my network again.
[admin@Stander] > /ip fir nat pr
I can only see it in CLI, as that field is hidden when masquerade is selected.
This is with ROS 5.25 on a SXT.
Try a src-nat instead of a masquerade in the CPE. Does this work?
add chain=srcnat action=src-nat to-addresses=10.1.3.2 out-interface=public
If public is not the name of that interface, change that.
