Packets finding way around nat
Hi guys,
I’m struggling with the following problem.
Mikrotik (HAP Lite) → WireTAP → DSL Modem
Firewall configuration:
# nov/06/2015 12:23:53 by RouterOS 6.32.3
# software id = I1XD-GX5R
add chain=input comment="Accept established connections" connection-state=established
add chain=input comment="Accept related connections" connection-state=related
add action=drop chain=input comment="Drop invalid connections" connection-state=invalid
add chain=input comment=UDP protocol=udp
add chain=input comment="Allow limited pings" limit=50/5s,2 protocol=icmp
add action=drop chain=input comment="Drop excess pings" protocol=icmp
add chain=input comment="From our LAN" in-interface=bridge-local src-address=10.0.1.0/24
add action=log chain=input comment="Log everything else" log-prefix="DROP INPUT"
add action=drop chain=input comment="Drop everything else"
add chain=forward connection-state=established,related
add chain=forward dst-port=500 protocol=udp
add chain=dstnat dst-address=213.135.XXX.XXX dst-port=500 protocol=udp src-address=10.0.1.201 src-port=500
add chain=dstnat dst-address=213.135.XXX.XXX dst-port=1701 protocol=udp src-address=10.0.1.201 src-port=1701
add chain=dstnat dst-address=213.135.XXX.XXX dst-port=4500 protocol=udp src-address=10.0.1.201 src-port=4500
add action=masquerade chain=srcnat comment="default configuration" out-interface=pppoe-out1 src-address=10.0.1.0/24 \
    to-addresses=0.0.0.0
When I’m looking in the dumps from the TAP I see bogus packets, but in general the system works. All packets are well pppoe encapsulated. But sometimes the NAT is not done. With a very small packet rate 5 Packets/Minute.
10.0.1.198 → 80.67.29.6 TCP 62 53389→993 [RST] Seq=1 Win=0 Len=0
Why the are going around NAT? Is it a bug … a broken rule? I have no clue. Typically everything should be in the pppoe tunnel and the source should always be my public ip address.
regards
Mathias
you also have to drop invalid connection packets on forward chain.
hi,
your solution worked out for me. But why are these packets generated? Are invalid packets not beeing translated to the public IP address?
kind Regards
Mathias
