Paket Loss rb532 and OS3.6
hy we have update from 2.9.5 to 3.6 to use Multicast service but the firm has a bug
there is a massive paket loss about 2% on 3 hours ( see attached file )
aslo after update the cpu load is toggle to 100% then 20 then 60 then 100 and so on …
can you tell me how to fix the problem ?
thanky
skynet
I experiment the same problem with rb333 and 532Ar5…
I’ve a sequence of packet loss every 30-40 ping. more in high traffic load.
I use rb 333 only with 2 ethernet port. I use /ip firewall mangle and /ip firewall nat and I lose packet in sequence…
ros v. is 3.2
with 3.7 paket loss is now ok …
thx for release 3.7…
My rb continue losing packet also with 3.7…
It loss packet only on ethernet interface..
I’m going crazy!
