HI all,
My RB doesn’t reboot after power failure. It only beep once, the green light come up once then off as normal, the blue light is on.
Tried netinstall but didnot detect anything…
:panic mode on:
HI all,
:panic mode on:
Check the output from console, perhaps you can reinstall RB1000 with netinstall.
thanks. It works now. by doing hard reset more than 6 times… ![]()
