PAP Authentication Not Work In Bridge Interface!
there are two ethernet interface and one bridge interface in my router.
ether1
ether2
bridge1 = ether1 And ether2
ip of bridge: 1.1.1.1
client in network can connect via pptp and l2tp with MS Chap protocol and everything is ok with this.
but everytime that client connect via pptp or l2tp with PAP or Chap protocol, connection is success but any packet will not receive from client!
I can ping client in router and client can ping router too and everything seems to be ok but it doest not pass any other packets.
This problem just appears when i set my authentication to use PAP or Chap and there is not any problem with other authentication protocol.
I have to use PAP or Chap Authentication.
Please somebody help me.
thanks.
PPPoE doesn’t have any problem with PAP and CHAP authentication protocol in bridge interface!
Is this Bug with RouterOS?
This sounds similar to a problem I’m having. I’ll try changing between PAP / CHAP . MsCHAP etc and see if theres a difference. But yes, possible bug?
