pap only pppoe connection have probability authentication failed
Hi, I’m a newer. I have a mikrotik Ros run in vmware as pppoe server which set it to pap only, and have a tenda router as pppoe client.
the tenda router have probability pppoe authentication failed, when change secrets from pap only to chap or replace mikrotik Ros to tp-link router, the issue is gone.
I use wireshark to analyze the traffics, I found that Tenda device send PAP authentication request and ROS pppoe server said ‘authentication failed’, But actually the pppoe secrets’s name and password is correct, if it keep trying to connect, Eventually it will.
I don’t know why will cause it. Is it really ‘authentication failed’? or it trigger by other things.
P.S. how upload my entire wireshark capture? I not found the option.
pppoe server Informations
interface pppoe-server server print Flags: X - disabled 0 service-name=“PPPOE server” interface=LAN(ether1) max-mtu=1480 max-mru=1480 mrru=disabled authentication=pap keepalive-timeout=disabled one-session-per-host=no max-sessions=0 default-profile=default
ppp profile print Flags: * - default 0 * name=“default” local-address=10.0.0.1 remote-address=PPPOE remote-ipv6-prefix-pool=(unknown) use-ipv6=yes use-mpls=default use-compression=default use-vj-compression=default use-encryption=default only-one=no change-tcp-mss=yes dns-server=10.0.0.1
1 * name=“default-encryption” remote-ipv6-prefix-pool=none use-ipv6=yes use-mpls=default use-compression=default use-vj-compression=default use-encryption=yes only-one=default change-tcp-mss=yes
Fail case:
Frame 2094: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface \Device\NPF_{53DA513F-B506-4878-AEFD-A6DBE2BEF4E1}, id 0
Ethernet II, Src: TendaTechnol_9b:36:b1 (c8:3a:35:9b:36:b1), Dst: VMware_9f:0d:78 (00:0c:29:9f:0d:78)
Destination: VMware_9f:0d:78 (00:0c:29:9f:0d:78)
… ..0. … … … … = LG bit: Globally unique address (factory default)
… …0 … … … … = IG bit: Individual address (unicast)
Source: TendaTechnol_9b:36:b1 (c8:3a:35:9b:36:b1)
Type: PPPoE Session (0x8864)
[Stream index: 34]
PPP-over-Ethernet Session
0001 … = Version: 1
… 0001 = Type: 1
Code: Session Data (0x00)
Session ID: 0x0007
Payload Length: 14
Point-to-Point Protocol
Protocol: Password Authentication Protocol (0xc023)
PPP Password Authentication Protocol
Code: Authenticate-Request (1)
Identifier: 1
Length: 12
Data
Peer-ID-Length: 3
Peer-ID: xfh
Password-Length: 3
Password: xfh
Frame 2095: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface \Device\NPF_{53DA513F-B506-4878-AEFD-A6DBE2BEF4E1}, id 0
Ethernet II, Src: VMware_9f:0d:78 (00:0c:29:9f:0d:78), Dst: TendaTechnol_9b:36:b1 (c8:3a:35:9b:36:b1)
Destination: TendaTechnol_9b:36:b1 (c8:3a:35:9b:36:b1)
Source: VMware_9f:0d:78 (00:0c:29:9f:0d:78)
[Stream index: 34]
0001 … = Version: 1
… 0001 = Type: 1
Session ID: 0x0007
Payload Length: 28
Protocol: Link Control Protocol (0xc021)
PPP Link Control Protocol
Code: Termination Request (5)
Identifier: 2 (0x02)
Length: 26
Data: 61757468656e7469636174696f6e206661696c656400
I’m really wondering why do you insist on using PAP (which transfers username and password in cleartext) over CHAP (which doesn’t exchange password) … specially as CHAP works in your use case?
Did you check log on MT? Does it say anything about the failed PAP authentications?
Because I need to use PAP as some router testing scenario.
I have checked log on MT, it is also authentication failed.
pppoe,info PPPoE connection established from 00:90:4c:88:88:88
pppoe,ppp, info : waiting for call…
pppoe,ppp, info : terminating… - authentication failed
pppoe,ppp, info : disconnected
After Debug, we found that when wan driver process pppoe pacakge too slow, which will cause this issue. just like have something timeout mechanism
