Parent Proxy
Hi ,
We have hotspot configured on Rb532.. my Internet comes with Proxy IP which is NOT Transparent.
I have created ransparent proxy and given parent proxy Ip and Its Port in Rb532. But Internet is Not working.
WAN IP - 172.16.32.101
LAN IP Pool for Hotspot - 10.10.10.1/27
Proxy IP - 172.16.32.100:8080
Is there any thing in Hotspot i have to mentioned…
Try a routing mark on a specific address for testing and add a default route to route to the proxy address.
HTTP should still work if you do this.
If it does not… Then fix your routes.
If you want transparent proxy from the hotspot then set it in the user profiles.
