paring AVM and wAP ax
I would like to connect a wAP ax to an AVM 7490 or 7590. The latest firmware is installed.
Only the WLAN radius is to be extended. No VLAN etc. A total of approx. 15 devices in the WLAN.
SSIDs for 2GHz and 5 GHz are the same, and the SSIDs for AVM and Mikrotek should also be the same. IP range is also the same.
As soon as the Mikrotik AP is set up, the WLAN no longer works here and I can no longer access the device via Winbox. Ping works perfectly.
What am I doing wrong? Have I made a mistake?
Are there any instructions for pairing the wAP ax with an AVM (7490 or 7590)?
TRY going to home setting above, then to the search box upper right and type in FRITZ
Then go to google and type Fritz Mikrotik
Then go to youtube and type Fritz Mikrotik
Ask chatbot to fix it for ya.
