this is work:
:local run [:parse [/system script get SCRIPT source]]
$run action=create user=username password=password
this is not work,… there is a way to make it work?
:local param "action=create user=username password=password"
$run $param
The reason that I want it like that because I want get parameters from string by telegram message…
The only solution that I found is:
:global run [:parse [/system script get SCRIPT source]]
:execute "\$run $param"
There is a better way?!
