hello i have a router ( model = CCR1009) with 3 partitions :
[Mikrotik] > /partitions print detail
Flags: A - active, R - running
0 AR name=“part0” fallback-to=next version="RouterOS v6.48.5 " size=42MiB
1 name=“part1” fallback-to=next version="RouterOS v6.48.5 " size=43MiB
2 name=“part2” fallback-to=next version=“” size=43MiB
I want to group the two partitions “1” and “2” in one .
Is it with this command that I can do it :
/partitions repartition partitions=1,2
is that after reboot the router will keep partition 0 as Active Running.
Thank you in advance for your answers
