I’m trying to get my traffic of a ip range go through my VPN
I’ve basically followed this guide
https://www.strongvpn.com/setup_mikrotik_pptp.shtml
The VPN is up but no traffic from my range is using the VPN
[admin@MikroTik] /interface> print
# NAME TYPE ACTUAL-MTU L2MTU
0 R ether1-gateway ether 1500 1598
1 RS ether2-master-local ether 1500 1598
2 RS ether3-slave-local ether 1500 1598
3 RS ether4-slave-local ether 1500 1598
4 RS ether5-slave-local ether 1500 1598
5 R IAmBridge1 bridge 1500 1598
6 R IAmNordVPN1 pptp-out 1400
[admin@MikroTik] /ip firewall nat> print
0 ;;; default configuration
chain=srcnat action=masquerade out-interface=ether1-gateway log=no log-prefix=""
1 ;;; default configuration
chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=ether1-gateway log=no log-prefix=""
20 chain=srcnat action=masquerade out-interface=IAmNordVPN1 log=no log-prefix=""
[admin@MikroTik] /ip firewall mangle> print
26 chain=prerouting action=mark-routing new-routing-mark=NORDVPN passthrough=yes src-address=10.0.0.5-10.0.0.200 log=no log-prefix=""
[admin@MikroTik] /ip dns>> print
servers: 8.8.8.8,8.8.4.4
dynamic-servers:
allow-remote-requests: yes
max-udp-packet-size: 4096
query-server-timeout: 2s
query-total-timeout: 10s
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 12KiB
[admin@MikroTik] /ip route>> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 IAmNordVPN1 1
1 ADS 0.0.0.0/0 198.48.196.129 1
2 ADC 10.0.0.0/24 10.0.0.1 IAmBridge1 0
3 ADC 10.10.10.1/32 10.10.10.14 IAmNordVPN1 0
4 ADC xxx.xxx.xxx.xxx/27 xxx.xx.xxx.xxx ether1-gateway 0
My router is not de DHCP server
thanks
