Passing OSPF messages through an IPSec Tunnel using GRE
Good Day,
I am trying to pass OSPF multicast messages over an IPsec tunnel on OS 6.15 (between two Mikritik routers) and I have been unable to get any of the OSPF message to go through. I have successfully setup my IPsec tunnel with NAT bypass and I can see traffic going through it appropriately. I have setup my GRE tunnel but I cannot figure out how to configure the IPsec tunnel to accept traffic from my GRE interface. From what I can tell and using wireshark it seems to be the issue.
I am successfully able to pass OSPF messages over the GRE link but when I configure the traffic to go through the IPsec tunnel my adjacency drops. I am using IPsec tunnel mode to encrypt the entire payload. I am learning how to use a Mikrotik router but I have done this type of thing before on a Cisco platform.
Right now I am using a test bed to do this using VM ware and the downloadable OS image. I am hoping someone can point me to some documentation to help with this because so far I have not found anything and getting frustrated.
Spekit
if both ospf neighbors are Mikrotik routers, then instead of gre you can set up EoIP.
And then encrypt the EoIP traffic with IPsec?
You may find it easier to set the network type as point-to-point and set the neighbors statically under NBMA neighbors.
