Passive Interfaces MPLS - VPLS RouterOS v7
Hello, Im doing an MPLS VPLS Lab and I made all the configurations but the VPLS tunnel doesnt work.
The only strange thing I see is that the connection with the neighbors is DOp. What does it mean for the interface to be passive?
SW-CORE
/port
set 0 name=serial0
add bridge=*6 interface=ether2
add bridge=*6 interface=ether3
add address=192.168.15.239/24 interface=ether1 network=192.168.15.0
add address=1.1.1.1 interface=lo network=1.1.1.1
add address=20.0.0.1/30 interface=ether2 network=20.0.0.0
add address=20.0.0.5/30 interface=ether3 network=20.0.0.4
/ip dhcp-client
add interface=ether1
add disabled=no dst-address=2.2.2.2/32 gateway=20.0.0.2 routing-table=main
suppress-hw-offload=no
add disabled=no dst-address=3.3.3.3/32 gateway=20.0.0.6 routing-table=main
/mpls interface
add disabled=no input=yes interface=ether2
add disabled=no input=yes interface=lo
/mpls ldp
add disabled=no lsr-id=1.1.1.1 transport-addresses=1.1.1.1
/mpls ldp interface
add accept-dynamic-neighbors=yes disabled=no interface=ether2
add disabled=no interface=ether3 transport-addresses=1.1.1.1
/system identity
set name=SW-CORE
/system note
set show-at-login=no
/tool romon
set enabled=yes
SW-NODO-1
add name=VPLS-TUNEL
/interface vpls
add arp=enabled disabled=no mac-address=02:DE:AB:FB:E7:22 mtu=1500 name=VPLS1
peer=3.3.3.3 vpls-id=1:1
/port
set 0 name=serial0
add bridge=VPLS-TUNEL interface=VPLS1
add bridge=VPLS-TUNEL interface=ether2
add address=2.2.2.2 interface=lo network=2.2.2.2
add address=20.0.0.2/30 interface=ether1 network=20.0.0.0
add address=192.168.1.1/30 interface=VPLS1 network=192.168.1.0
/ip dhcp-client
add disabled=no dst-address=0.0.0.0/0 gateway=20.0.0.1 routing-table=main
add disabled=no distance=1 dst-address=1.1.1.1/32 gateway=20.0.0.1 pref-src=“”
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/mpls interface
/mpls ldp
add disabled=no lsr-id=2.2.2.2 transport-addresses=2.2.2.2
/mpls ldp interface
add accept-dynamic-neighbors=yes disabled=no interface=ether1
/system identity
set name=SW-NODO-1
/system note
/tool romon
set enabled=yes
SW-NODO-2
add name=VPLS-TUNEL
/interface vpls
add arp=enabled disabled=no mac-address=02:5A:60:BF:D3:E9 mtu=1500 name=VPLS1
peer=2.2.2.2 vpls-id=1:1
/port
set 0 name=serial0
add address=20.0.0.6/30 interface=ether1 network=20.0.0.4
add address=3.3.3.3 interface=lo network=3.3.3.3
add address=192.168.1.2/30 interface=VPLS1 network=192.168.1.0
/ip dhcp-client
add disabled=no dst-address=0.0.0.0/0 gateway=20.0.0.5 routing-table=main
add disabled=no dst-address=1.1.1.1/32 gateway=20.0.0.5 routing-table=main
/mpls ldp
add disabled=no lsr-id=3.3.3.3 transport-addresses=3.3.3.3
/mpls ldp interface
/system identity
set name=SW-NODO-2
/system note
/tool romon
set enabled=yes
For those who are interested, find the following information:
In MPLS (Multiprotocol Label Switching), a passive interface on a Mikrotik router refers to an interface that does not actively participate in the exchange of MPLS labels. In other words, the passive interface on a Mikrotik router does not perform MPLS packet tagging or untagging.
In a typical MPLS scenario, routers that are part of the MPLS network exchange MPLS labels to route packets efficiently through the network. However, in the case of a passive interface, the Mikrotik router simply forwards the MPLS packets without modifying the MPLS labels associated with them.
In summary, a passive interface in MPLS with a Mikrotik router is an interface that does not perform active tagging or untagging operations on MPLS packets, but simply forwards the packets as it receives them.
BUT MY VPLS TUNNEL ISNT WORKING YET.
I have a similar post to you, as per some folks here they said v7 has still some bug in VPLS even though everything seems right the VPLS tunnel is up IGP is up and BGP sessildons is all up it still won’t work… If you really want to make VPLS work make the P router as Route Reflector with v6.49.X it should work
This works for me, it worked but not really great because you still have ros v6 at play
Ok ok, let me try.
You need the Route Reflector. Without it, doesnt work, right?
Where did you find this?
