Passive parameter in IPsec->Peer
Good afternoon,
I’m using Mikrotik’s chr-6.48.3 version to make a script that creates a site-to-site IPsec tunnel. Whenever I run the command “ip ipsec peer add passive=no” via script or console the parameter “passive” is set to “yes” instead of “no”.
Has anyone had this problem? Is there any solution to solve the problem?
Any help, I appreciate it.
Compliments,
Daniel Rodrigues
passive=no is the default, no need to pass that in your command!
Good afternoon pe1chl,
I’ve tried it without passing the “passive” argument in the command and the behavior is the same.
Good afternoon,
Problem solved. It is necessary in the script to specify the peer address.
