Password Encryption using md5.js
I uploaded md5.js to my webserver and copied an example hotspot config from a post in the archives. I am not poficient with Javascipt, so I played around with the syntax for a few hours, and I am still getting the error that the “router will not accept unencrypted passwords”.
If I did set the router to accept unencrypted passwords, my test html file look like:
After questions - login page
This is a page that would include the hidden username and/or password which would be fed to the router after questions were answered
\ \ Since I want to use the md5 hashing, could anyone who has done this before, please post an example of what html I would use to accomplish the example above, but with the MD5 hashed password?
Much thanks in advance.
The example posted in the archived post called “Hotspot Javascript Encyption Example” did in fact work correctly once I first tried to use it without modifying it. Then I just put my test user “Ex” and password in and it was fine. I suppose when I tried it the first time I changed too much info and inadvertantly missed something..
Thanks to ADAVIS who was nice enough to post this the first time…
Here is the actual test script I used on my webserver. Change “YOURIP” to the IP address of your MT router. The and is the test user I entered in my MT, and the (not required) is the destination that the user is sent to after they login instead of the MT status screen. There is also a submit button which proves it works. If you embed this code in a dynamic webpage served by a database then the submit button would not be needed since the code would execute upon an action in the application.
[color=green]
<script language="JavaScript" src="/md5.js">
</script>
<form name="sendin" action="http://YOURIP/login" method="post">
<input type="hidden" name="user" value="Ex">
<input type="hidden" name="password" value="Ex">
<input type="hidden" name="popup">
<input type="hidden" name="popup-present" value="true">
<input type="hidden" name="domain" value="">
<input type="hidden" name="dst" value="http://www.google.com/">
<input type="submit" name="login" value="Login">
</form>
<script language="JavaScript">
  function doLogin() {
    if (document.login.popup.value == 'true' || document.login.popup.value == 'false') {
      document.sendin.popup.value = document.login.popup.value;
    else {
      document.sendin.popup.value = document.login.popup.checked;
    document.sendin.user.value = document.login.user.value;
    var frmXXX = document.login.elements['domain'];
    if (frmXXX) {
      document.sendin.domain.value = document.login.domain.value;
    document.sendin.password.value = hexMD5('\130' + document.login.password.value + '\142\004\003\132\264\003\100\344\226\202\355\325\136\304\070\355');
    document.sendin.submit();
</script>[/color]
Thanks again to ADAVIS for the old post of the js example…
