password for graphs
hey guys,i enabled the graphs on my mk but i want to put a password,so i need to put a password when viewing the graphs how can it be done?? thanks
you can not add password to graphics (for now, i don’t know if in the V3 will add this feature)
Maxi
Currently you can only set access per IP address. You can use remote servet that collectes and manages SNMP data, enable web-server there (e.g. Apache), restrict access to graphs per IP address.
Sergejs, I posted this somewhere else in the forum, is it possible to allow acces to ONLY graphs, from the web interface ?
I mean not the login screen and the rest ?
In 2.9.x ?
Simple solution what I’m using is changing web port in IP/SERVICES/WWW
If you put some other port, for example 8282… only who know that can access to your graphs :slight_smile:
Indeed. :smiley:
But also anyone can test the machine for open ports, find this, and this way gaining access to the web interface also. Or, by knowing this, erase the /graphs at the end of the url. And the same result. With login and the rest. :smiling_imp: :cry:
