I’ve dug up a flash disk with an ancient install of Mikrotik 2.9rc1 on it. No-one here can remember the password from back then. I don’t suppose I can do a Net Install or something on it to reset the password and regain the use of the license?
Yes, reinstalling will reset config, but license should stay. I don’t know about this old version though, I think you will need to purchase a new license to use v3. You need to find an installer from back then
I’ve plugged the CF card in, loaded up NetInstall, clicked on the drive, and nothing really has happened, all the software-id/key/save config fields are disabled.
