Hello, we are having trouble with the firmware vulnerability on older ROUTEROS versions.
We started a HUGE Upgrade Process to remove old routeros versions, but for some router it was too late.
Despite we always set a different complex password, and despite 8291 is accessibile only from our management subnet, some router-boards have been hijacked and we cannot access them anymore.
Is there a way to reset the router without pressing the reset button?
This is because we have several DYNADISH mounted on top of roofs and are phisically inaccessible .
For Exampe other CPE manufacturer have a reset button in the Power Supply Unit and you can factory reset from there.
I had a little googling on “Mikrotik reset from psu”, but nothing…
Thanks to all
