Password Reset
Good Day Everyone.
I bought a mirkotik haplite (config included) then when i asked for the admin full access he wont give it to me.
my question is that i also want to learn to config the router myself. problem is if i reset the router he said his warranty on scripts will be void.
is there any way i can view his config with no full access then search scripts in the web alone?
Thanks sorry for my bad English
No. You did wrong agreement. You can reset everything or negotiate with the script provider.
I thank for your reply and effort.
If i reset everything ill begin from a scratch which i am open to explore.
my problem now is where to begin.
can i ask for a learning list?
God speed
The list :
https://wiki.mikrotik.com/wiki/Manual:TOC
The rest depends on what you need to achieve.
