Good day. I am using dual WAN on my home setup, and I disconnected on:
-after launching PoE. Sometimes it just stay on the “connecting” phase and doesnt go to checking resources
-after logging in the character page doesnt show up
-maps doesnt load or if I change a map/instance
-and sometimes I just get disconnected for any reason
Although I have 2 internet connection, I did set TCP ports 8095,12995,20487,32000-65000 to use single a single WAN only. I also have captured a few PoE IPs and set it to the same WAN as the TCP ports. If I use WAN1 I cant connect to the game at all. If I use WAN2 then the disconnection I listed above occurs.
Any idea how to fix this?
My mikrotik setup is that I mark the connections for TCP ports 8095,12995,20487,32000-65000 with passthrough. Next thing I mark is the packets for Queue Tree still with passthrough. Last thing is for the mark routing to the specific WAN i want to use.
Karl
